Thread: Intellichlor IC40 AC question
    May 2016
    Pensacola, FL
    4
    Hello,
    I have a Pentair Intelliflo Variable Speed pump with the programmable timer. I just upgraded to a Intellichlor SWG and power generator. The tech hooked the AC for the power generator to the pool breaker. When the pump is running everything is operating as expected according to the manual. However the manual says to never have the SWG "on" when the pump is not running. My schedule is having the pump run for 12 hours a day. Now when the pump is off the salt indicators alternately flash. The Flow light is red which I assume means that the system is "off" and not generating chlorine. Is this OK? Or should there be some other connection to the pump that would cut off AC to the SWG when the pump is not running?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,508
    Re: Intellichlor IC40 AC question
    Barney,
    Your SWG should only be on when the pump is on. In your case, it will need to have some type of timer that is set to run the same as your pump. The red low flow light is fail safe system to prevent the SWG being on when there is low or no flow. It is not supposed to be used as the primary cut off. The world will not end, the way it is currently set up, but I suggest you look into getting a timer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    We had a post over the weekend about somebody's SWG (IC40) exploding and destroying their plumbing. Luckily nobody was nearby. The reason is because the SWG was on when the pump was off and there was gas build up. Here is the thread, New Member Swade
    I also have an Intelliflo wired to the breaker and running about 14 hours a day. My SWG is wired to a timer and I run it about 9-10 hours a day. I check fairly often to make sure the clocks are in sync and leave an hour or so on each side with pump on and SWG off for extra safety.
    Mar 2016
    Blue Springs, MO
    28
    Wow, I was coming here to research this very question. I run mine through an Easytouch system, and thought there would be some kind of way to shut them both off/on at the same time via a schedule. I'd prefer not blow up my equipment pad just yet, lol.
    16x36 inground pool - 8.5 deep, 3.5' shallow vinyl - Pentair VS 011018 Pump, Hayward 72 SQ FT Pro-Grid Vertical Grid In Ground Pool DE Filter, Easytouch 520705 (with IC40 SWG), Pentair Mastertemp 300 (460734)
