Thread: Top not level but water depth is.. almost, is it safe?
    Hi
    Due to soft ground on one side my poles have sunk by a couple of inches so the surface to liner measurement is out on this side to the opposite by 2 1/2 inches BUT the depth of the water measured from the same two opposite spots is only 2 cm (excuse mixing my scales) - I don't understand the physics of this to know whether the pool is safe or not.
    To me it seems like the top edge of a bag of water should be able to vary quite a bit and that its the volume of water I should be worried about, but I see a lot of people measuring from surface to liner as opposed to to depth, so maybe I am wrong.
    Thanks in advance for any clarification.
    j
    12ft above ground Intex
    Jun 2014
    15,192
    Re: Top not level but water depth is.. almost, is it safe?
    Hello J and welcome to TFP! Here at TFP, we generally say that our above ground pools should be level with a variance of about 1 inch. That's measured across the top of the pool and water surface since we know that no matter what's happening with the structure or ground, water will always remain level. Being 2 1/2 inches now, our concern would be the amount of pressure applied to the short-sided wall and any increased possibility of collapse. We surely wouldn't want that to happen. Ground settling is a frustrating occurrence after a pool is set-up, and we see this happen many times each year. In most cases, we recommend stabilizing and re-leveling the structure for the safety of the swimmers and the structures nearby.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You may be able to lift each post with a helper or two and slide another paver under it. I would definitely try to slide a 2" paver under the posts.
    Quote Originally Posted by pooldv View Post
    Wow that would be a result, I just took some slabs out from elsewhere in the garden.
    Think it will need something like 4 people though!
    If only I could get the car jack under it or something....
    Might have to let some water out.
    Thanks!
    Casey's Avatar
    SW PA
    10,452
    Definitely drain some water out to do this repair.
