Thread: Adjusting return eyeball
    May 2012
    Allentown, PA
    219
    I have some problems with my eyeballs (that is pool eyeballs) if I make them too tight they won't move if I make them too loose they eventually fall off. I want to snug them a little bit, but still be able to move them. I'm thinking about greasing them, but I'm not sure what type of grease is pool friendly? They are hayward and have 3 parts to them. Any suggestions?
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Adjusting return eyeball
    Quote Originally Posted by doublewide6 View Post
    Safest bet is to grit your teeth and go to the pool store and buy a tube of pool lube. Otherwise go to a hardware store and ask for some silicon grease. Don't use a lot of either, just a film is enough.
    Jul 2015
    Central Valley CA
    1,109
    I have been using the silicone I use for beer making on some of the pool components, it's fairly cheep on Amazon HERE
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
