Thread: Pressure Side Leak
    Jul 2014
    Manalapan, New Jersey
    98
    Pressure Side Leak
    New pool...mostly fixed but noticed there is a tiny, very tiny leak of water just after the pump (there's more water in the pic due to my hose). After a few hours there is a small puddling of water and if I push just above the leak area, I can see a tiny tiny bubble but nothing significant. I can't actually see water flowing from there it's so slow of a leak. Looking at it, it seams they tried to caulk around it to seal it? Assume that's a useless attempt to fix it, or is it? Does this leak even cause any big issues? Can I use silicone caulk around it? Don't want to spend $200-300 for the pool company to fix this small section of pipe if I don't have to (new pump motor, new blower, salt system... Need a money break for a few weeks lol)
    23k gal in-ground gunite w/ spa/blower, Sheer descent, Jandy AquaPure SWCG, Pentair 2HP Pump x2, Raypak P-R406A-EN-C 399k BTU gas heater, Polaris 380/Polaris PB4-60 Pump, DE filter w/ separation tank
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Pressure Side Leak
    No, caulk won't help. That pipe is threaded into the pump and needs tape or dope to seal it. But, a leak that small on the pressure side is not an issue. I would not bother with it.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,776
    If you are lucky over time a pin hole leak like that will seal itself. If it turns into a steady stream or spray it will need some attention. The only way to fix it properly would be to cut the pipe ( assuming there isn't a union near by that isn't in the picture) and unthread the nipple. Clean off the threads best as you can apply new sealant and put it back together. Not all pipe dope is compatible with PVC so read your labels before using it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2008
    San Antonio, TX
    129
    High-Temp Union - CMP
    These are the way to go, especially on Whisperflo pumps.
