Thread: Finding leak in vinyl pool
    Annettebjrd's Avatar
    Apr 2016
    Lafayette Louisiana
    21
    Need suggestions on finding a leak in my above ground vinyl pool.  I visually inspected the entire pool from the deck but don't see anything obvious.  I know I need to get in and inspect up close, but trying to narrow down the area since the water is still pretty cold 😳.
    21 foot above ground round; 10,000 gallon; Pentair Dynamo 340210 1.5 HP pump; Pentair Sand Dollar Filter SD-60
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Finding leak in vinyl pool
    Don't add any water to top off the pool and let it get to where the water stops. Often where it stops is where you find the leak (assuming it is on the side of course).
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    We had to hire someone with an electronic leak finder. The hole was TINY and I had looked and looked. I would not have found it without them. The wet place where the we say the water was on the other side of the pool from the leak!
    I had to call around to find them but it was worth it after DAYS of diving and looking. They said "it is right here" while standing on the side of the pool with their machine. I got in and found it right away since I knew where to look. It was tiny!
    Kim
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,524
    Maybe turn off pump and drop some floating things in to see where they go? Maybe ping pong balls? You could weigh some down with tape or hot glue so some float in the middle of the pool and some near the bottom. Maybe you get lucky and one catches the current? No clue, just brainstorming.
    Maybe use a food safe dye in still water and watch the flow? Maybe it points you towards it?
    I used American Leak Detection once. Several hundred dollars, but fast, professional, and perfect.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
