Thread: Bag attachment for suction side vac head?
    My pool builder left me with a suction side vac head with roller wheels. I'd like to use it to get the bulk of the leaves out when I open the pool... instead of running my dolphin on about 15 cycles to get them out over the course of a week. Save wear and tear on my Dolphin and speed up the process. Problem is, I'd like to keep from having to empty the pump strainer a lot of times... and also keep as much of the junk out of my clean DE filter. Is there any kind of filter/bag I can attach where the hose plugs into my skimmer intake that will pre-filter a lot of the junk out? I don't care of it lets small stuff back in the pool. As long as I get all th ebulky leaves out... my dolphin will have an easier job getting the rest.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Jun 2014
    15,205
    Re: Bag attachment for suction side vac head?
    Do you have a multiport valve on your DE filter? You could just vacuum to waste and shoot that stuff right into the yard.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    How about an inline leaf canister?
