Thread: Repairing Vinyl Liner
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Our liner has split. We do have a piece to patch it with. The color will be off, but we are trying to make it through this season. As you can see from the attached picture, the water level is down some. You'll notice that the liner has pulled out from the wall some, but it is attached at the top. Do you think if we patch it, that it will hold? If so, what's the best way to go about this. I'm assuming we will need to drop the level even more for repair because of the way it's pulled out. If so, how much lower should we go? I would appreciate answers as soon as possible because if it can be repaired, we would like to get on it so that I can start balancing the water. Right now we have several hundred tadpoles in it! If we have to go the new liner route, we would install ourselves. What company would you recommend buying from? As you can see, I couldn't post a picture. It is ripped about an inch and a half from where it attaches at the top, is about 18 inches long, and is pulled out from the wall about 4 - 5 inches.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Repairing Vinyl Liner
    No pic...
    Isolated Spa - 345 Gallons
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If you can't get your picture to load, try using a hosting site like Photobucket, and copy and paste the IMG code into your post here.
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Sallie
