Results 1 to 7 of 7
Thread: CSI Question
    Jun 2015
    The Woodlands, TX
    23
    CSI Question
    Just tested my pool and thought my levels were good until I hovered over my CSI calc of -.36..."Potential to become corrosive to plaster"
    Say what?
    24000 gallon pool, in ground, plaster, pebble tech pool deck, SWG, cartridge filter. What am I doing wrong here? Here are my levels:
    FC 5
    CC 0
    TC 5
    CH 350
    pH 7.5
    TA 60
    CYA 60
    Salt 3000
    Bromates 0
    88*
    Blue Haven Pool, 24k oval, Quartz, Hayward smart flilter 550sf, cartridge, AQL-PS-16-x288 Controls, AL turbo cell SWG, Polaris pressure side cleaner, Spa, Hayward H400IDL2 heater, Rock water fall
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: CSI Question
    Let pH climb a little or raise TA.
    If you want immediate results, a 4 lb box of baking soda will take TA up to 70 and drop CSI to -.25
    Jun 2015
    The Woodlands, TX
    23
    Re: CSI Question
    Thanks Richard. Just found that while adjusting the calculator. Borax will raise pH as well, correct?
    Jun 2014
    15,221
    Re: CSI Question
    Borax for pH rise - yes. Good you noticed the CSI row. Now that you have you'll always key-in on it. That's good.
    Jun 2015
    The Woodlands, TX
    23
    Re: CSI Question
    A touch of panic, but yes, I always check the CSI row. I've noticed 2 areas of discoloration in the shallow end and near my drain. I wonder if the plaster corroded in those areas? This is my 2nd year on TFP, so I'm still a newb to this!
    Richard320's Avatar
    Jan 2010
    19,051
    Re: CSI Question
    Quote Originally Posted by YouRang View Post
    Yes, but baking soda is easier to find late on a Sunday afternoon.
    Jun 2015
    The Woodlands, TX
    23
    Re: CSI Question
    Agreed. I've been running my waterfall regularly trying to get the pH up too. I got a little carried away with the muratic acid. I chased my TA all summer last year so i was trying to avoid chasing my TA all summer again. I tested it last night with an old Leslie's kit and had TA of 130, so either last night is wrong or tonight is wrong. I tested twice tonight, so I'm sure TA=60 is correct.
