Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Salt water cell probs
    May 2016
    Cookeville Tn
    17
    I just recently replaced my Hayward circuit board with an after market board by Optimum. The prob I have is that when I start the system up, the power light and no flow light comes on. When the no flow light goes out, the generating light comes on for about 2 mins and then goes out and the check salt and check cement lights come on steady. I have checked the cell, re-installed it, pushed the diagonistic button and held for 3 secs, but the check salt does not reset - stays on steady. My salt reading has been at 2200 but today started showing 2100. Do I just need to add more salt or could my cell need replacing?
    Hi, I am located in Middle TN area, have a 16' x 32' vynal liner, in ground pool and am using a T-9 Hayward Salt Generator system.
    Jul 2015
    Western NC
    115
    Re: Salt water cell probs
    You probably have to add salt, but you should test the water for salt before adding any.
    I use the Taylor K-1766 salt test.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    That sounds low, what does the manual recommend for optimum salt level? Most SWGs want 3000ish ppm.
    The board usually comes preset for the T15 cell. Since you have a T9 cell, you have to change the setting or the salt will read low. Push the diagnostic button until T15 is displayed and then move the switch from auto to superchlorinate and back to auto until T9 is displayed.
    If the setting is correct, the salt might be low or the cell might be wearing out.
    How old is the cell?
    Have you verified the actual salt level?
    Support the site
    May 2016
    Hazelwood
    25
    The check salt and inspect cell will come on if salt level is below 2500ppm add more salt till 3000ppm and recheck
    May 2016
    Hazelwood
    25
    If the problem still occurs the salt cell is bad, most pool stores can test them..
    (Pool technican for 4 years)
    Jul 2015
    Western NC
    115
    The water should be tested with a reliable salt test before salt is added.
    Really no need to bring an aquarite cell in for testing. If the salt reading on the box is right, the cell is fine.
    The volts tells you if the circuit board is good and the salt reading tells you if the cell is good.
    Support the site
    May 2016
    Hazelwood
    25
    Quote Originally Posted by JamesW View Post
    Yeah if you have a salt tester and the salt diagnostic of the board is (-2500) and the salt tester says 2500 you don't have to get it tested. 9/10 people don't have a salt tester and an aquarite board
    May 2016
    Hazelwood
    25
    But your salt cell could also still be bad and be giving a good reading on salt but not generating. Seen it multiple times
    May 2016
    Hazelwood
    25
    Just do yourself a favor go to the pool store that will test your cell and a water sample. Have them test the water sample first. If the salt is on par with your board the cell is probably good.
    If not have them test the cell. Don't do unnecessary steps
    A bad cell won't give a good instant salt reading. If the instant salt reading is correct for at least ten minutes, the cell is good.
    Support the site
    May 2016
    Hazelwood
    25
    This is completely incorrect
    The salt reading is calculated from the performance of the cell. If the cell is underperforming, the instant salt will read low. For the salt reading to be good, the cell has to be performing properly.
    Note: You have to give a few minutes for the readings to stabilize.
    Support the site
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Re: Phosphates can also cease a salt water pool from generating chlorine
    But right level of chlorine for the relevant CYA level= no algae= no need to worry about phosphates
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    38,428
    Side discussion about phosphates was moved HERE.
    May 2016
    Cookeville Tn
    17
    Thanks everyone! Took a sample of water to pool store - salt level tested low. Added 4 bags of salt and seems to be working great now. Thanks again.
    38,428
    Great!!!
    Now get your own Taylor salt test
    Do you have one of the Recommended Test Kits for all the other chemistry parameters?
    May 2016
    Cookeville Tn
    17
    @jblizzie re test kit - No I don't. I have been using a reg chlorine/ph/alk/acid kit that I had when I changed over to salt and taking a sample to pool store about every 2 wks for them to test. When I test my salt I have been using salt strips. I generally have very few probs with my pool. But, I have been wanting a kit for ck'ng the salt readings. Which one would you recommend?
  20. Back To Top    #20
    38,428
    Please get one of the recommended test kits and stop trusting the horrendous pool store testing before you DO have a problem ... you may already have a problem and not realize it.
    For the salt, there is only 1 Taylor salt test: K-1766
    And I recommend the TF-100 as the best value for the overall test kit ... which also uses Taylor reagents
