Thread: How long to SLAM?
    bellebrit's Avatar
    Jun 2014
    Madrid, Iowa
    44
    How long to SLAM?
    Hey all, we are on our third summer with our pool. I am usually the one taking care of the pool, but last summer I was pregnant with, then gave birth to twins, so my husband was in charge of the pool. Needless to say he didn't test it or put chemicals in it once all summer, so the pool sat and didn't get used at all. The first summer we had the pool we took it down at the end of the season but it was a pain so this past winter we left it up. My husband just drained the water and left everything up with the cover on.
    Two weeks ago he got in there and scrubbed everything clean and filled up the pool, then it sat, for two weeks, with no chemicals I just went out, did my initial testing and added everything I needed to balance the pool except for the chlorine. There's no algae or anything, but since the pool has been sitting for 2 weeks I'm sure I need to SLAM it? How long should I keep the chlorine at SLAM level?
    Brittany, Pool Owner since June 2014
    Intex, AG, 18'48" Ultra Frame, 7,600 gal, Laminate PVC, model #: A18'48"FG0114RO, Krystal Clear Filter pump model 635T, Leslies Complete DPD test kit model 81330.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How long to SLAM?
    Quote Originally Posted by bellebrit View Post
    Same criteria:
    Water is clear
    CC is less than .5
    Overnight test loses less than 1 FC.
    It could be over in less than 24 hours if there's no algae. Take it up to shock level now, test again after the sun stops shining on it, and test again tomorrow morning before the sun hits it. If it passes, you're done. If not, add more bleach.
    bellebrit's Avatar
    Jun 2014
    Madrid, Iowa
    44
    Ok great, thank you so much!!
