CJadamec
the lines on the curve are for nominal motor hp rating. The is 1/2hp low speed and 1/2 hp high speed. They simplified the low speed side of the chart because at low speed the other motors fall between the 1/2 hp motor and 2 hp motor curves. If all the curves were on there you wouldn't be able to read it.
As for why to get a dual speed or variable speed over single speed its pretty cut and dry. At 3250 rpm your 1hp motor is using roughly 750 watts per hour. If you are able to drop your rpm down to say 2900 with a VFD your motor will use about 375 watts. If you drop your motor to 1100 rpm with a VFD or dual speed switch your motor will use less than 100 watts per hour. SO based on 8 hours run time a day a single speed motor will cost about $18 a month to run. A dual speed motor will run you about $2.40 a month to run. I rounded you electric rate to $0.10 /Kwh to make the math easier. That's why the higher cost of a VS doesn't really pay out for you. For me however my cost per Kwh is $0.22. Your actual motor wattage may vary these are just basic numbers.
