Thread: Actual Parts List for Hard Plumbing
    Jun 2015
    PW virginia
    16
    I know this has been talked about on here many times but i'm trying to find an actual parts list to do the hard plumbing on an intex pool. I've seen a ton of pictures but just not sure what to actually use on the inlet and outlet holes of the pool itself. The rest is pretty easy to figure out.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Actual Parts List for Hard Plumbing
    I used normal inlet/outlet through wall fitting Amazon.com : Hayward SP1023G Vinyl Fiberglass Inlet Fittings for Pools, Spas and Hot Tubs : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    And if you look at this thread I gave everything I used, my pictures and the new install with pictures
    I hope this helps
