Thread: hayward pool pump seems to have died
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey all,
    I have a multi-speed hayward pool pump.
    Opened a few days ago. Everything was working fine. Of course pool is the usual swamp after opening here
    Pump was running ok. Then went to backwash. My cheap backwash hose ripped.
    So turned off the pump and replaced it. That hose hooks almost to an extended pvc "arm" off the filter.
    That can move up and down. I always lift it to put the hose on. I can hear water flowing back into the system through that "arm" but it never seems to effect things.
    This time however, when I turned the pump back on to backwash, it ran for about 15 seconds and completely died. No power or sound coming out of it at all.
    Is it possible something got back into the pump and got stuck or blew it out?
    And if so would it be possible for me to take apart and check?
    Or does this type of thing normally require a new pump?
    Thanks a million.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Jun 2012
    western NY
    1,559
    Re: hayward pool pump seems to have died
    By "completely died" do you mean the motor is not turning on or the motor is running but nothing is pumping?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by danpik View Post
    Its not turning on at all. Nothing. Silence when I hit the switch.
    Jun 2012
    western NY
    1,559
    Are all breakers On? Do you have power at the motor?
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Yes. I tested all power. Its definitely the motor.
    Thanks a lot.
    Jun 2012
    western NY
    1,559
    No hum sound from it? Did you check all connections at the motor? Can you turn the impeller or motor shaft by hand?
