Results 1 to 9 of 9
Thread: Scaling along waterline tile and in grout.
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    I've read several posts on how this happens but can't seem to find many that tell how to clean this up?
    Does anyone have any suggestions?
    Thank you!
    My Build 20x40 Freeform Shotcrete (33k gal) pool. 3.6-8.6, Blue Granite Pebble Sheen, Tennessee Flagstone Coping, Sta-Rite System 3 Modular Media Cartridge Filter, Intelliflo 4x160 x SVRS, Rainbow Automatic Chlorinator, 1 LED light, Tanning Shelf, 15.6 Slide with 3 different height jumping rocks, Sta-Rite 333k btu propane heater, kool deck, TF100, Dolphin Oasis Z5
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,511
    Re: Scaling along waterline tile and in grout.
    If possible, please take a picture and post it here.
    Whatever you try, be sure to test it in a small, less prominent spot first.
    Someone used a magic eraser cleaning sponge and loved it. Be careful if you try that, abrasive and strong.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    This is all around the pool. At some points, it travels into the plaster.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    That is efflorescence, it is caused by water behind the wall pushing minerals through the grout. Diluted muriatic acid and a stiff brush are probably the best option. Of course, proper safety precautions are a must.
    Apr 2016
    Central Florida
    1,511
    Great work on the picture!!! Now that pooldv identified it for you, you can search for efflorescence using the search box towards the upper right off the page and read the stores of similar pool owners. You may want to then add other keywords you find, for example, efflorescence muriatic acid, or, efflorescence pressure washer, or efflorescence grout. Once you have a basic grasp on things, you might have questions, which you can ask here or, if the other thread is recent/active there too.
    Pressure washers and muriatic acid are both capable of doing more harm than good if used incorrectly, not to mention dangerous. They might also be your solution if used safely and correctly! Whatever you decide, probably best to try it on a spot first, just in case.
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    Thank you for your responses. I have tried MA already and it somewhat works. I mixed 1:5 with water and put it in a spray bottle. It will just take me forever plus having to hang over the pool....ugh. I was crossing fingers that there may have been an easier solution.
    Is this going to happen no matter what? Even if pool is balanced?
    Apr 2016
    Central Florida
    1,511
    Now that you know what it is, I'd start a new thread with name like. "Efflorescence: What worked for you?" in a better category to really grasp the experts in that category sorry I can't be of further help on this one. Don't give up. People on this site have tried tons of things and maybe someone has a nice twist to what you're doing or a trick or something else entirely!
    38,267
    Please do not start a new thread. If you want this moved, report your post (little triangle icon with ! in it) with the request. You can also change the title by editing the first post in the Advanced Editor.
    DFW, TX
    24,483
    It'll be easier once you can get in the pool! This is not a water chemistry issue. It is a ground water issue behind whatever is on the other side of that wall. Is it wet back there? Can you improve the drainage?
