Results 1 to 9 of 9
Thread: Storing acid
    May 2013
    Needham, MA
    140
    Storing acid
    Is it ok to leave a bottle of muriatic acid in one of those giant rubber storage bins? I just bought a bottle for the first time in preparation for our new pool. I thought the bottles were vented, but the kind I bought is not. The rubber bin would be stored in my garden shed which at one point was an old garage attached to the house. Always cool in there. If it helps I bought the Jassco 34.5% bottle from Lowes.
    BTW, Lowes has on sale right now a 3 pack of standard chloride bleach for $4.24.
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Storing acid
    That sounds fine for the acid. Cool and away from metal stuff.
    Did you see the datecode on the bleach? It might be on sale for a reason.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Storing acid
    Yes, a rubbermaid bin is fine. I wouldn't snap the lid on too tight, because if it does vent, when you open the lid you'll get overwhelmed.
    May 2013
    Needham, MA
    140
    Re: Storing acid
    Quote Originally Posted by pabeader View Post
    Where do I look to see the code, and what should I be concerned with? I did by a case.
    Richard320's Avatar
    Jan 2010
    19,055
    Re: Storing acid
    Quote Originally Posted by rmclain73 View Post
    Chlorine Date Code Decoder/Easy Way to Measure Strength.
    Today is the 129th day of 2016
    May 2013
    Needham, MA
    140
    Re: Storing acid
    Looks like day 47. I need to take it back anyways. There was a big display of regular bleach, and a big display of splash free. I grabbed from the regular display, but got a case of splash free. Grrrr...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Storing acid
    Good thing you noticed that!!! Would have been no fun to find out after you started adding it.
    Richard320's Avatar
    Jan 2010
    19,055
    Re: Storing acid
    Looks like day 47. I need to take it back anyways. There was a big display of regular bleach, and a big displayed if splash free. I grabbed from the regular display, but got a case of splash free. Grrrr...
    Return it.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: Storing acid
    Yep, splashless is no good for our pools. Foams up good in a HE washing machine too.
    The acid is very stable over a wide range of temperatures, you can keep that outside. I buy one gallon at a time and keep that in a white 5 gallon bucket with a lid, which fits fairly tightly. The lid keeps what little fumes that make it past the cap contained, and I haven't even noticed much at all in the way of fumes with my bucket. The metal bucket handle doesn't even have the slightest hint of corrosion. Here's how it looks (appropriate hazmat placard optional )
    Attachment 36590
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
