Thread: Cutting a Solar Cover for Free Form Pool and What Reel?
    May 2016
    Atlanta, GA
    89
    We just purchased a solar cover for our pool after mice destroyed the one we stored for the winter in my mom's shed. We have a free form pool so I purchased a rectangular shaped cover and plan to trim. We laid it out over the pool for three days and then did a "rough" trim. I could have sworn that I read somewhere that you should let your cover sit for two weeks before doing a final fitted trim but now I cannot find that. Does anyone know if that is the case or are we ok to go ahead and do the final cut?
    Also, we are interested in a reel for the cover but can't believe how they range from $250 to $1500. Such a difference! Any recommendations or things we need to consider when purchasing?
    Thanks!
    Kristina
    14.5'x32' irregular shape Pebble Tec SWG pool; 12,000 gal; Purex Triton Tagelus Sand Filter; Pentair IntelliPh Ph Controller
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Cutting a Solar Cover for Free Form Pool and What Reel?
    Hey christina, I cut mine 10 minutes after I had it on the pool (had to find scissors )
    As far as cover reels, they are crazzy aren't they.. I went with this one and it is working good for me
    Amazon.com : Deluxe Above Ground Pool Solar Cover Reel - Up To 28 Feet Wide : Swimming Pool Solar Reel Systems : Patio, Lawn Garden
    But this one is for an above ground
    here is one that looks close to the same Amazon.com : Rocky Garden
    May 2016
    Atlanta, GA
    89
    Well you have been a TON of help in every way CowboyCasey! Thank you!
    Guess we will be holding off on buying a reel though!
    JoyfulNoise's Avatar
    May 2015
    13,236
    Look up posts by user mas985. He has a link in his signature for a DIY reel using DWV PVC pipe (the pipe floats on water). It's a DIY version of The Solar Roller reel system. I plan on cutting my new cover as well this week. Leave it in the water for 24-48 hours to let it shrink/expand as needed and then do a final trim cut.
    Matt
