Thread: Calcium for Vinyl pools???
    Jun 2008
    North Carolina
    38
    How low is acceptable for vinyl pools? Mine is at 30. If I need to raise it, what chemical do I need?
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Calcium for Vinyl pools???
    Quote Originally Posted by amersonl
    Recommended levels listed in Pool School show 50 to 300 is okay.
    Calcium increaser (calcium chloride) can be found at the big box stores, Lowes, HD, &...... pool stores. Not sure about WallyWorld, tho. Follow the instructions on the label.
    Post back if you have any q's.
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You can also use Calcium Hypochlorite (granular shock) sold at pool stores and WW for FC purposes - it will bump your CH more slowly though, but it is an option to kill 2 birds, yada yada yada.
