Thread: Where to start
    Jun 2012
    Blaine, MN
    106
    Where to start
    Hi everyone,
    We pulled the winter cover off yesterday (Saturday). Scooped a few leaves out, lightly scrubbed the walls and put the solar cover on. The pool guy is coming on Friday to get the pump and heater ready to go. I hope to get the chemicals where they need to be before he comes. Questions for my pool gurus.
    Where do I start? I know the TA and PH are important to get right so we don't ruin the heater (installed last fall, haven't used it yet).
    PH is 7.2-7.5 (hard to tell with the color test)
    FC 1
    CC 0
    TC 1
    TA 40
    CYA 0
    Thanks
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Where to start
    You can't really test or treat the water without circulation.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Where to start
    Maybe pick up a cheap submersible pump to at least get the water moving around?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2012
    Blaine, MN
    106
    Re: Where to start
    Quote Originally Posted by pabeader View Post
    Great idea. I have one or two of those? Any suggestions what to do next for chemicals?
    blondemarcello
    Minnesota
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Where to start
    PH between 7.2 and 7.8 will keep your heater good. PH below 7.0 is what can hurt your heater. Add 30 ppm of CYA in a sock in front of a return or pump and SLAM the pool if there is algae, Pool School - SLAM - Shock Level And Maintain. Or maintain chlorine if there isn't. Chlorine CYA Chart.
    As a member since 2012 I assume you have one of the recommended test kits. You can add it to your sig if you want.
