Thread: First Time Pool Owner. Gunite pool with copper plumbing needing some guidelines
    Oct 2014
    Iowa
    10
    I have a gunite pool that was built in 1950. It is plumbed with copper. Is there any precautions I should be taking regarding chemicals due to the copper piping?
    Thanks
    38,548
    Re: First Time Pool Owner. Gunite pool with copper plumbing needing some guidelines
    The only thing that would really cause a problem would be allowing your pH to get too low and pull copper into the water.
    Oct 2014
    Iowa
    10
    Could I use a chlorinator with it?
    38,548
    Define chlorinator. If you mean with tablets, I would not as that puts acidic water through the pipes. Plus we generally do not recommend that use of pucks anyways. If you mean a SWG, that would be no problem.
