Thread: Jandy Lite2 "FL 0"... again.
    May 2015
    Abbotsford, BC
    17
    Most recent posts on this issue are about three years old, so since the system suggests I start a new one... here I am.
    So, same old story: firing up the system for spring, and the Lite2 gives me the FL 0, which is an error in the safety circuit. I found one old post that suggests bypassing the "three" devices in line... the troubleshooting guide shows four: pressure switch, two limit switches, and a fusible link.
    I've found the pressure switch and fusible link behind the front panel... but where are the limit switches??
    "After a time, you may find that having is not so pleasing a thing, after all, as wanting. It is not logical, but it is often true."
    Pool: 80,000l (21,000 USG) 32'x'16' in-ground concrete with vinyl liner
    Sep 2013
    Charleston, SC
    537
    Re: Jandy Lite2 "FL 0"... again.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
