Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
Thread: First ever Pool Test...and not the last!
    Apr 2015
    Boston MA
    93
    First ever test....my apologies in advance...here goes...
    Test conditions.... New England-Raining-50F
    FC-0.5
    CC-0.5
    TC-1.0
    CH-75ppm
    TA-80
    CYA-crystal clear-tested 4 times and continues to present the 'black dot.'
    K-1000 test results
    CL/BR- 0.5-1
    PH-8.2
    Lastly, I did not perform the Salt Water test. I do have the kit here, however I'm unsure how to perform this test.
    I'll look at Pool math in the a.m. However, thanks everyone for your help and patience... Here's to a healthy and fun summer---(once I get this pool thingy).
    Cheers, Derryank.
    12,000 Gal,IG Vinyl,Pentair 1HP Dynamo,Pentair SD40,Pentair Intellichlor SWG,Dolphin Nautilus, TF-100
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: First ever Pool Test...and not the last!
    Great job on the testing! Now to interpret the results! When you enter all the results into Poolmath it will tell you what to do to lower the pH, increase your CYA and increase your Chlorine.
    Love TFP? Become a
    TFP Supporter!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    nice, just plug those numbers in poolmath under "now" column and put the recommended level you want (down at the bottom of poolmath) and then put that level in the target column
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    You left out a biggie: what does the water look like?
    If it's green and you have no CYA, there's a slight chance the CYA degraded into ammonia over the winter. If it's a fresh fill, we'd expect to see no CYA since it doesn't occur naturally. I don't want to get into a whole long description of the next steps without knowing the background, otherwise a simple answer might become a confusing longwinded post.
    Apr 2015
    Boston MA
    93
    Hi Richard... My apologies. It's a fresh fill. The pool is crystal clear.
    Thanks for the help
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by derryank View Post
    Thanks for the help
    Well then it's easy to get things fixed up!
    With no CYA in the water, your target FC is 3. That's just under half a 121 oz jug of 8.25% bleach. Less if you have some stronger stuff handy. You can just eyeball that amount. It'll all be gone in a few hours anyway, but that's normal and expected at this point.
    Your pH may actually be higher than 8.2. Anything above that reads as 8.2. So don't assume you did something wrong if you add the called-for 20 fluid ounces of acid and it's still at 8.2. Just repeat it.
    Adding CYA is pretty straightforward. 4 lbs of the granular stuff will take you to 40. So pour the whole canister into a sock or two and set it in the skimmer or dangle it off a pole in front of a return.
    In order... Add acid with the pump running. Brush a few times in different directions to get it all mixed. Then fumble with the CYA and the socks. By the time you're done messing with that, the pH should be fixed, or at least close. Recheck it and see if you need moire acid. If yes, add. If no, move on to bleach.
    The CYA will take a day or two to dissolve all the way, so it's a special case. Otherwise, give yourself 15 minutes or so between chemical additions. Brushing ensures it's well distributed.
    As soon as the pH is between 7.2 and 7.8 and you have some Chlorine in the water, it's safe to swim.
    When the CYA is dissolved, your new target FC will be 5 and your minimum is 3. You might need to target a little higher or lower to ensure the FC doesn't dip below 3 before you add again. Time and testing will tell you that.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Look at you doing the tests and posting the results! NICE! How is the PH doing? Is it behaving and going down like it should? The socks with the CYA can be tied off to a chair or even tied to a noodle and left to float around the pool BUT hanging in front of the return will make it dissolve faster. Make sure to keep it out of little one's hands. You can put it in a bucket of water while they are in the water and pour the water into the pool and rehang the sock once they get out.
    Kim
    Apr 2015
    Boston MA
    93
    Hi all....no bleach yet...just getting around to it now...busy doing Mothers day!!
    Quick question... Even though it's a SW pool...step 1 is still bleach?
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,009
    Yes. Get it running and balanced as a bleach pool, then add the salt, then turn on the SWG and stop using bleach.
    Apr 2015
    Boston MA
    93
    Here we go!!! Thanks Richard, ID be bloody lost with you guys.
    Step 1 is now commencing
    TF-100 test kit
    Apr 2015
    Boston MA
    93
    Bleach pool first means...turning off the Salt Water generator!!
    Step 2.....20 fluid oz's of Muriatic Acid-to lower the PH to 7.2 to 7.8
    Step 3.....CYA 4lbs...I think I have this in tablet form? --- 3" chlorinating tablets? If not...I'll need a trip to the pool store
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,009
    The tablets have chlorine as well as CYA and they're very acidic. Are you ready to try juggling three parameters at once? To raise CYA where you want using pucks would mean adding about 100 FC to the pool. That will bleach your liner and they're slow dissolving, so figure about a month. Go buy the granular stabilizer. They sell it at Lowes and Walmart and places like that.
    Apr 2015
    Boston MA
    93
    On my way to Lowes
    TF-100 test kit
    Apr 2015
    Boston MA
    93
    Hokey Dokey......
    PH 7.5
    CL BR 3-6
    Time for the socks?
    TF-100 test kit
    Apr 2015
    Boston MA
    93
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks Kimkats...actually rather excited learning a whole new language/concept.
    However I need to reiterate how grateful I am for yourself and others-ahem, Richard, for your sincere assistance for those in need.
    Thanks so much
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,009
    Hokey Dokey......
    PH 7.5
    CL BR 3-6
    Time for the socks?
    Yep. If it won't all fit in one, use two. And if they block the skimmer flow, hang the second one in front of a return.
    Apr 2015
    Boston MA
    93
    Happy days Richard...let's see how I get on....
    Update...the socks are installed. One in the skimmer and one in front of the return.
    THANK YOU so much!!!
    TF-100 test kit
    Jul 2012
    Tallahassee, FL
    30,525
    SWEET! You can also squeeze the socks to help it dissolve. When you are adding everything else use your TARGETED CYA in Pool Math.
    Kim
    Apr 2015
    Boston MA
    93
    Squeezed the socks this morning! Nearly all gone now...the pool is still greenish? I'm assuming this is normal and within the 48 hour period.
    I'm headed over to Pool math now to see the FC levels
    TF-100 test kit
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,525
    It will take a couple to a few days to clear all the way. Each day will be better! Taking a picture looking down at the steps will help you see the difference.
    Kim
