Thread: tear in liner
    tear in liner
    Spent the afternoon helping friends install a new pool liner in an inground pool. We were quite far along in the install process when a tear was discovered along the weld seam. This was not an installation fault but obviously a weak point in seam. They have to wait till Monday to contact the company they purchased liner from, but just from anyone's experience/knowledge, is there anything that can be done to repair this or will a replacement be forthcoming? Or should they be weary if company wants them to 'just patch it'? Thanks.
    22,500 gal A.G., vinyl, sta rite crystal sand filter- Pentair Water Pool & Spa , Hayward Super Pump Self Priming 10" lift, BBB method
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: tear in liner
    Seam failure (the seam is where 2 sections of liner were heat welded together) is about the only thing the warranty is good for and on a brand new liner it should be 100% covered. A patch would be acceptable while waiting for the replacement liner, but they've gotta replace the liner!
    A few years back the company we get our liners from had a new pattern - there was someing wrong with the material or the process of imprinting that pattern which caused every liner we installed with that pattern to fail at the seams The company honored the warranty but discontinued the pattern due to the problem, so the owners had to choose a different pattern.
    Luv& Luk
    -Ted
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: tear in liner
    I agree with Ted
    A new liner with a Manu-Defect, I would accept nothing less than replacement.
    Mar 2007
    4,160
    Re: tear in liner
    Quote Originally Posted by frustratedpoolmom
    I agree with Ted:
    That's what I like to hear!
    Luv& Luk
    -Ted
