Thread: Bio Active
    Apr 2015
    tucson, arizona
    1,107
    Bio Active
    Was wondering if any members have used a product called Bio Active. It is used to reduce (remove) CYA from the water. I have tried it once with poor results, although talking to there reps they believe I didn't follow all there directions. Would try again but would like better direction from a member
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Bio Active
    There were a number of folks that have tried it and to the best of my knowledge, none were truly successful. There were reported decreases, but upon further investigation it was found to be attributed to testing error or water exchange.
    We even had a member work at length with the tech support folks but in the end they needed to drain and refill.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,238
    Re: Bio Active
    As far as I have seen, it is just another magic potion that does not do what it claims.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Bio Active
    As the others have said, when this product showed up a year or so ago there was great interest in it, and we had a few experienced members try it out and in the best case the results were marginal at best, and within the margin of error of the test at worst. I think everyone was hopeful that this product would be the real deal, and it just not seem to be that, at least not when used as directed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Bio Active
    Do a search on bio active in the upper right corner and you can read the threads from last year.
    There is a bacteria that consumes CYA and it shows up in a few people's pool every year and usually takes their CYA down to 0 and leaves a bunch of ammonia in the pool. It takes the perfect scenario that seems to include a lower water temp and low to no chlorine. I assume the bio active people are trying to replicate this scenario. But, it doesn't seem to work reliably or with predictable results.
