Thread: In process of balancing pool SLAM but noticed water below arrow leaking?
    Apr 2015
    Nashville
    40
    Could it be leaking? I had it fixed 2x through the years. I lower my water yesterday just a little and refilled it. Backwash, rinsed a few times. I check near skimmer with leak detection but found nothing to be leaking. Water is still too cold to go under or even in the water. I ideas?
    Liner
    23,000+
    4-11 ft pool
    With steps
    Rectangular pool
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: In process of balancing pool SLAM but noticed water below arrow leaking?
    I am not sure what the arrow is or where its leaking from, could you show us a picture of the leak?
    Apr 2015
    Nashville
    40
    Quote Originally Posted by cowboycasey View Post
    I do not even exactly know if there is a leak in the pool or the filter. Let me check it tomorrow morning..
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    May 2013
    Long Island NY
    419
    My experience with patches is they need to be redone every couple of yrs to play it safe. They tend to get crud around the edges and eventually the patch fails. I check mine each summer and if they look bad pull and replace them. I don't want those to fail when the water is 45 degrees and I have my cover on.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Try performing a bucket test. Put a rock or two in a 5 gal bucket, put it in the pool and fill it with water to the same level as the pool. Check it every 24 hours for a couple of days to see if the pool level drops faster.
    Please add your state to your location in your profile so it show up over there <-----, climate is an important factor when we are helping you with your pool. Nashville is a city in 8 states.
