Thread: More chemical questions
    Jan 2016
    KS
    60
    ok I took my water sample in to a local pool place... They read my free chlorine at 3.5 and my total chlorine of 4.4 so advised I shocked to remove the combined chlorine... They are telling me to put 15 bags of their "Burnout 35" in it.. They pointed me to the display and they were almost $8.00 each.. needless to say I bought none. I understand the bleach in the pool to keep free chlorine out but how do I remove/lower the combined chlorine ?
    Also they read my CYA at 151 and they told me as long as it is under 200 it is fine. I have turned off my chlorinator until I figure all this stuff out and going to purchase all the bleach.
    36,000 Gallon, 40x20 IG, Vinyl, Hayward S- 200 Sand Filter, 300,000 MasterTemp heater, 1hp Superpump, Polaris 9550 sport, TF100 test kit
    Re: More chemical questions
    Pool School - SLAM - Shock Level And Maintain
    Burnout 35 is lithium hypochlorite. No benefit over liquid chlorine. Just use liquid to Slam. You need a good test kit to get accurate information. The TF100 is the preferred kit.
    Support the site
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    The first thing you need to do is order the TF100 or K2006 test kits. The pool store testing will lead you down the garden path. Their advice that as long as your CYA is under is 200 is very poor advice.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jun 2014
    15,153
    Definitely run in the other direction and rely on your OWN testing.
    Jan 2016
    KS
    60
    ok I get around 100 - 125 CYA so I am going to drain and refill and then shock so I do not have to reach 40 FC.
    Is it a safe assumption to make that the CYA was probably that high because the previous owners did not monitor it and did not do partial drain and refills while running Trichlor tabs and dichlor granules.
    I know I probably raised it some running the chlorinator (same as previous owners) but couldn't imagine in less than a month it went up from 50 to 100+?
    I would imagine it would take several months to raise it up that high again?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Each 8oz trichlor puck raises CYA by 3 ppm. For every 1 ppm of FC added with trichlor 0.6 ppm of CYA is added. So, if your pool uses 3 ppm FC per day then pucks add 54 ppm CYA per month.
