Results 1 to 8 of 8
Thread: Best base for pool legs
    Apr 2016
    Providence RI
    11
    Hello,
    I am installing an intex 12'X24'x52" rectangular pool. I am confused about what kind of base to put under the legs. Intex says to use 15"X15"x1.2" pressure treated wood, or steel pads or reinforced tiles. I can't seem to locate PT wood that is 15" wide, and I've read that the wood breaks under the weight.. I have no idea where to buy steel pads or reinforced tile. I've also read in various threads that 1 inch patio pavers break. Is there a consensus on the best thing to support legs on this type of pool? I read in a few thread that 16'x16'x4 is a good choice. But, I have to special order those (not carried locally.) Do 1.5 pavers work? Any tips on where to find steel pads or reinforced tiles? This pool has 18 legs to support. I previously had a 15' round intex on this spot, but we never used pavers. I want to get the pavers right the first time so we don't waste time/effort/water. Thanks for any insight you have!
    Jul 2014
    Oakbank, Canada
    389
    Re: Best base for pool legs
    Any steel shop in your area will make you steel plates to you spec. 1/4" thick steel plate will be adequate, will not rot, break, and last you pretty much forever. Lots of steel scrap yards also get cutoffs of plate steel that may match your size requirement.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Apr 2016
    Providence RI
    11
    Thanks for the tip DarrelB. I checked out steel pads with some local guys, and they are rather expensive. (I'd end up paying almost as much as the pool costs for the number i need-yikes!) Anybody have any feedback on pavers or wood?
    Casey's Avatar
    SW PA
    10,457
    You'll need very thick pavers to support the load with this pool. Like 4" pavers they set trailers on. Or, you can make your own footer yourself. It's a thought.
    Jun 2015
    Stockholm, Sweden
    250
    I use 2" pavers on top of solid, level base. Works fine.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Apr 2016
    Casa Grande, AZ
    66
    Mine was probably one of the threads about the 1" pavers snapping (I unfortunately did have to drain and rework!). I went to 2" thick by 16" wide and 12" deep pavers (HD sells them for about 5 bucks each) as I also trying to keep costs down if possible. Its only been 10 days or so - but these seem to be solid and holding well and the legs show no signs of buckling at all. Our pool is slightly smaller than yours though - but in theory that weight/stress should be distributed about the same.
    Intex 18'x9'x52 - 2800 GPH Sand Filter/Pump - TF100 Test Kit
    Jun 2015
    Tacoma/wa
    10
    These are 1 & 1/2 inch and work great. Walmart
    New Intex 24x12x52 above ground pool.Rich
    Jun 2015
    Tacoma/wa
    10
    And the rocks are not under them. Just level dirt.
