Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: First opening
    Aug 2015
    LAWRENCEBURG, IN
    47
    First opening
    Hi guys. This is my first year opening the pool after I had the company that put the liner in new last year do it. Well, I have a very green swamp. Pool is at fill level now and here is what I got with my test:
    PH 8.2
    Alk 170
    Calcium 100
    What should be my first step of getting this cleaned up. My new pump arrives Monday, so I haven't started anything yet. I have 4 gallons of liquid shock (10%) and a bottle of algae control 60. Thanks for the help!
    21000 gal.
    Vinyl liner- new spring 2015
    Purex Triton Tagelus sand filter
    Hayward 1hp pump
    Jun 2014
    15,255
    Re: First opening
    Tough without a pump to circulate. But when you get the pump hooked-up, the pH would be first as it's currently high. Do not use the algae control. I suspect you will need more bleach for a SLAM that could take a week or more. You should also test your CYA now just to get an idea. If it's zero or below 30, buy some granular stabilizer and have it ready, but don't add it yet. Once the water can circulate for about an hour, test everything once more to confirm and let us know.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Yes, my CYA was 0. I figured I was going to need more bleach 😔
    Jun 2014
    15,255
    Re: First opening
    ha ha. Yes... more bleach. Once your pump is hooked-up, we may even have you do the 10-min ammonia drill just to be safe. Depends on your first readings after circulating. We should know for sure Monday evening.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Thanks for the help Texas, I'll post what I got once I get it up and running
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Picked up 10 more gallons of chlorine and some stabilizer to be armed and ready
    Jun 2014
    15,255
    Re: First opening
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Ok, have my new motor hooked up and running but having trouble getting it to actually pump
    Jun 2014
    15,255
    Re: First opening
    Trouble priming you mean - filling-up the pump strainer basket? Make sure the basket is full of water first then secure lid before turning-on. Check pool water level and ensure the skimmer flap (weir) is not stuck shut. All valves are open.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Yes, trouble priming. All valves are open and basket is full. Water level is good, I even put s hose directly into the skimmer
    Jun 2014
    15,255
    Re: First opening
    If all you did was slip a new motor up against that existing wet-end, and the motor itself is cranking-up fine, then we have to review the basics:
    - Motor, seal plate, etc firmly attached, no chance of incorrect configuration of impeller or diffuser or leak?
    - Suction side air leaks all ruled-out?
    - Distance from pool to pump? Some pumps allow up to 5 mins +/- to pull water a substantial length/grade
    - No obstructions on the pressure side preventing the pump from pull/pushing water?
    Those are some brainstorming ideas that popped into mind.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Yes, slipped on new pump to existing wet end. Everything firmly attached and assembled correctly. Distance from pool to pump roughly 12 feet. I gave up for the night. My buddy that opens/closes pools on the side is going to look at it tomorrow morning while I'm at work.
    With basket full, it pumps what is in there, just not wanting to draw it from the pool
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Pool is up and running. Slammed once up to 12 and cleared up A LOT over night. Had to wait a couple days (needed a new pump seal) and slammed again last night up to 10. Just checked chlorine again and was at 5. PH currently 7.2-7.4. TA at around 170.
    Jun 2014
    15,255
    Re: First opening
    Good you have the pump running again. Just remember ... a SLAM is a process that typically takes days or a week or two to complete. You definitely want to pass the 3 SLAM criteria or it will just come right back. Let us know if you have any questions. Have a great weekend.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    I'm adding stabilizer at the same time, is that practical? I checked it today after adding maybe 1.5 pounds and it was still close to zero
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: First opening
    Its fine. Takes 5-7 days to register so save your reagents.
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    👍🏻 thanks!
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Ok, here are some pics of my progress. Just fighting the cloudiness now.
    21000 gal.
    Hayward 1hp pump
    Jun 2014
    15,255
    Re: First opening
    Lots of progress!
  20. Back To Top    #20
    Aug 2015
    LAWRENCEBURG, IN
    47
    Re: First opening
    Took this pic this evening. I had to backwash a lot the last 3 days, but filter is holding steady now (only rising a couple PSI). I have vacuumed to waste once and stayed on top of brushing (even though my brush is somewhere on the bottom of the pool and can't see it yet ). I'm still losing some FC overnight. One question I do have is, can I cover the pool at night while slamming?
    21000 gal.
    Hayward 1hp pump
