Thread: Which plaster finish is the best?
    Oct 2014
    Lothian/MD
    10
    After dealing with our PB regarding a faulty plaster job, it looks like they are offering to replaster our pool.
    We initially had the standard Diamond Brite Antiles Aquamarine color.
    Is there a better finish we should consider for this replaster?
    Thanks in advance,
    Rich
    23,000 SW Pool, Shotcrete shell, #501 Antilles Aquamarine Diamond brite plaster, Jandy JE series heat pump, Jandy Stealth Pump, Jandy cartridge filter, Polaris 360 cleaner,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Which plaster finish is the best?
    It is generally considered that pebble lasts longest, quartz second and regular plaster third. Some of the better known brands are Pebbletec, NPT, Wetedge and Diamond Brite. The key to a good plaster job is the installation crew.
    More here, Ten Guidelines for Quality Pool Plaster
    And here, Diagnosing Pool Plaster Problems
