Pool just opened (first time pool owner!): questions on cleaning and pressure
Pool just opened yesterday, and I am a bit overwhelmed. Will continue discussion of water testing on a previous thread, but I have specific questions on cleaning and filter pressure.
1. Cleaning: Pool was under a mesh cover all winter. When it came off, water was clear, some algae along edge of pool and on top step with a "decent" amount of debris and muck on the bottom. Pool guy got the Polaris 360 going, threw in a bunch of shock, ran pump continuously. Today, there are a few streaks where the Polaris seemed to do its job, but less than I would have thought. Plus it is mostly floating in the middle of the pool. I finally figured out how to hook up the manual vacuum but wasn't sure how much of the perceived progress was vacuuming or just stirring up the much at the bottom. I also brushed the algae off the edges (pool guy had brushed off the step). Questions:
a) How do I get the Polaris to stay on the bottom? Wheels running, water jet off the back seems to be pointing at the 10-11:00 position (what pool guy said it should be), pulled float to 1.5 inches away from body, water jets seem to be shooting water into bag as appropriate. If working, can this thing really clean a newly-opened pool?
b) Am I doing manual vacuum right? Pool has 2 skimmers and drain. From Googling, I filled the hose with water from a return, kept it under water to the skimmer, and put it into a hose-shaped opening with the basket removed. I did lift the vacuum near the surface and did feel suction of sorts. I put a tennis ball in the other skimmer to increase suction on the vacuum. My doubts are about its effectiveness and whether it's okay to vacuum debris right into the filter (?) without a basket or anything in between.
c) Any tips on getting this pool cleaned in general post-open? I am a bit overwhelmed. The manual vacuum seems tedious and only marginally effective, and the Polaris, after that good start, isn't working great. Am I missing something?
2. DE filter pressure. Pool guy said baseline is 16-18 after opening it yesterday. This morning, pressure was 25, so I backwashed it. Turned pump off, backwash for about 30-40 seconds, pump off rinse for 10-20 seconds; repeat 2 times. Put in 5 pounds of DE into skimmer. Pressure back up to 16. Yay! However, later, I noticed pressure down to 10. Hmmm. Turned pump off then on, pressure goes back to 15. But then it drifts down to 10-12. What's wrong? Could this have anything to do with vacuuming debris right into the filter?
