Results 1 to 8 of 8
Thread: What's the max amt of CL allowed ?
    Houston, TX
    1,099
    Hello to All,
    If we plan on leaving for a week, and do not want to employ pucks, what the max volume of liq CL [a total FC = ?] we can use that will not damage the equipment or other? I use 8.25% liq bleach. As noted, pool does has 400K heater. Spa and pool approx. 15K gallons in-ground w PebbleSheen. CYA = 40-50 range
    If there is anything else you need, pls let me know?
    Thank you very much,
    tsex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: What's the max amt of CL allowed ?
    I would just use a floater with 3 inch pucks in, this will chlorinate and keep your PH down while you are gone. Being in houston, 50 CYA is probably a good thing..
    Use the bottom of poolmath to figure out how much chlorine and CYA it will add with each puck, most pucks are 8 oz
    The great thing about TFP is knowing how and what you're putting in your pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    I'd still raise my FC level close to SLAM level for your CYA------THEN also add the floater.
    Jul 2015
    Charter Oak, California
    273
    TsTex:
    I went on vacation last November and followed the advice from the TFP Experts. Brought the pool to just over Slam Level for my CYA, filled a floater with 3" pucks and left the sliding release door on the floater about half open. My pump was on 6 hour a day using an automatic timer. I also tied the floater in two places in front of the return with enough line so when the pump came on the floater full of pucks was was pushed to the center of the pool.
    When I returned after 12 days, the pucks were almost the same size as when I left and my CYA had only increased a bit. Water was crystal clear and chlorine had not dropped below the recommended norml daily level for my CYA.
    All the advice I've ever gotten here has been spot on. You will be fine. Nothing to worry about while you're gone.. Enjoy.
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Agreed with above. Raise FC to shock level for your CYA, assume 50 if it is questionable. Lower PH to 7.2. I also agree that a few pucks won't hurt at all but I don't use them when we go on vaca.
    Houston, TX
    1,099
    Thank you. You all have given me a good idea of what I need to do.
    I raised my pool to a SLAM FC of 20 after rain spillover into the pool...it last for about 4-5 days before it was back to the 4-6 range...So if I do the same w no prior "funk and algae", then it should last longer...can get a floater and string it to stay in the middle deep where there's a lot of motion from pool returns. My 3HP VSP runs from 8am-4pm daily. As also in a slam you lower your pH, I would do the same....
    THanks again,
    tstex
    Houston, TX
    1,099
    PS - I have a CL puck dispenser on the equip pad. By recommending a "floater", is this if you do not have a CL dispenser, or is there an advantage for using a floater over the CL dispenser? Thanks again, tstex
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,102
    You can use your puck dispenser as if it was a floater. Only put pucks in there if you need them.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
