Thread: Vinyl liner problem
    Mar 2014
    Edmond, OK
    17
    Vinyl liner problem
    Rookie mistake here (though it's our 3rd year with the dumb pool). After a recent heavy rain, we syphened (sp) too much water out of the pool. Now our vinyl liner appears loose. It is still attached all around the rim (and the bottom from what I can tell) but it is not attached to the sides of the pool. Is this fixable? Will adding water back into the pool push the liner back where it needs to be? Is all lost and we need a new liner?
    Thanks!
    Natalie
    Supercal
    18,000 gallons, above ground pool, vinyl liner. Swim Pro SW256T Sand Filter, 80GPM, 35 GMP/ftsq
    More than 3 years old
    Well water
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Vinyl liner problem
    Hey there neighbor
    It should push back against the wall just fine, you may get a wrinkle or 2 but that's about it.. as long as it's still connected all around the top it's good
    Mar 2014
    Edmond, OK
    17
    Thanks, Neighbor! We are the processes of filling....hope it works!
    Supercal
    Well water
    Casey's Avatar
    SW PA
    10,453
    How's it look?
