Thread: Backwash on 1/2 Speed
    Apr 2015
    Pasadena, CA
    56
    I have a variable speed pump and am wondering if it's ok or effective to backwash at half speed? My line drains into an area of my yard that gets all disrupted when I do it at high speed. Thx.
    22,000 gallon IG plaster pool, raised spa w/spillover, variable speed EcoStar pump, natural gas heater, 60 SF DE filter, SWG (all Hayward), AquaLogic automated controller, Kreepy Krawly, TF-100 Test Kit
    38,521
    Re: Backwash on 1/2 Speed
    You have a very large pump so there is a very good chance that half speed would be a sufficient flow rate to backwash the sand effectively.
    Apr 2015
    Pasadena, CA
    56
    It's actually DE not sand, so would that make it more likely to be okay?
    38,521
    Sorry I can't see signatures on Tapatalk. It still might be fine. Although I've kind of lost faith in the ability of De filters to be back washed and really they should be broken down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I'd have to agree jblizzle. I backwash for a brief period of time, maybe thirty seconds, to loosen the obvious stuff. Then I open my filter and blast the screens with a spray nozzle and reassemble and then backwash again to finish. I suppose it helps that my filter has an internal backwash that drains out the bottom. If yours does too, then low speed should be plenty of flow.
