Thread: leaking drain plug
    leaking drain plug
    I have a hayward sp0714t filter. Just noticed the drain plug is leaking- its cracked on the side. Is there any kind of glue that will help? How do I go about repair? Is there a way to keep all the sand from running out with a gush of water when I take the plug off?
    docelect
    30k gallons in-ground vinyl
    1.5 hp pump 300 lb sand filter
    Polaris cleaner, T15 Hayward SWG
    Jackson, Mississippi
    Re: leaking drain plug
    correction. sp0714t is the valve. Filter is s244t
    docelect
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Kill the power to the pump so the timer doesn't turn it on while you're still fussing with things.
    Turn the multiport to Rinse and see if that will let some air creep in and the water in the filter to drain back out through the pump. If it doesn't, then set it back to filter and just loosen the drain plug so the drip turns to a trickle and then go do something else for an hour or two. Then when you do remove the drain plug, you won't lose but a handful of sand.
    If that plug is standard pipe threads, your nearest hardware store should have something that fits. I wouldn't even bother trying to glue things.
    Thanks for the tips. So much better than trying to take things apart. What I called a plug is actually a threaded cap, so it sounds like what you advised should work. Thanks again.
    docelect
