Thread: Sealing Travertine Pavers
    Sep 2012
    Los Angeles
    99
    My deck is composed of tumbled travertine pavers, and I have left it unsealed mainly because i do not want it to become slippery. For anyone with experience with sealing a travertine deck, does doing so make it slippery, or do you just have to get the right kind of sealer to make sure it does not get slippery?
    Rectangular pool 28x16 and spa 8x7, 17,000 gallons, IG, Tropics Blue Mini-Pebble, Jandy 60 DE filter, saltwater cell, Jandy VS pump, 1.5 hp Jandy spa pump, 400k heater, 5' Sheer Descent with 1 hp Jandy pump, Jandy color LED lights. Build Thread
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Sealing Travertine Pavers
    If you use a sealer, water will stand on the pavers. For me this is an advantage because it tends to sheet over to the drains rather than pool on the deck. I do not find this makes our stones slippery because they have a lot of natural texture. We used the DuPont Stonetech and are very pleased. My seven year old slipped once while running but that was a lesson learned.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    JoyfulNoise's Avatar
    May 2015
    13,199
    DuPont StoneTech OR DryTreat 40sk are both "penetrating" sealants. The sealant liquid is applied/mopped onto the stone surface and allowed to sit for a short period of time. You then sponge it off and let it dry. The process allows the sealant to penetrate the porous stone and the curing process let's the sealant chemistry bond to stone material and create a water-impermeable layer WITHIN the stone. This is supposed to leave the surface texture the same although the stone color can change slightly.
    Depending on weather conditions, sealants do need to be reapplied on a regular basis. Usually every few years or so.
    Matt
    Sep 2012
    Los Angeles
    99
    Good to know that you are happy with your sealing results. Thanks for the advice!
