Results 1 to 9 of 9
Thread: pump and filter size for AG 15x30
    May 2016
    Clark, NJ
    6
    Post pump and filter size for AG 15x30
    hi, new guy here. just bought a 15x30x54" Sharkline Matrix pool (I believe about 11,000 gals) and getting all different recommendations from pool sites for proper pump and filter size.
    I want a dual speed pump, which would operate at low speed most of the time. Is a 1 hp pump with 1/2hp at low speed be good enough or is a 1.5hp (3/4hp on low) a better option. Also is 100sq ft filter more than enough or do I need 150sq ft? I'd like a bigger filter than minimum required but don't want to overkill or spend extra cash if not needed. Hayward makes a 1hp/100sqft combo and Pentair has a 1.5hp/150sqft combo, both 2speed. I can buy separate filter and pump but doesn't come with the mounting base.
    thanks for your help, much appreciated.
    PG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: pump and filter size for AG 15x30
    Welcome to TFP
    It is confusing isn't it... I have almost the same pool (16x32) I went with a pentair 1hp 2 speed and a pentair cartridge filter 320sqft... We believe bigger is better and huge is even better (i have a 100sqft filter on my 700 gallon hot tub)
    You do not have to go that big as the cost is up there.. 1 hp 2 speed is is a great pump and works well and a 150sqft filter will just need to be cleaned more during the season, I only clean mine once a year.
    I hope this helps
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,795
    I too have a 15 x 30 pool going in shortly. Went with a superflo VS pump. Check for rebates it might might a VS pump more economical. In general for filters the bigger the better and longer time between cleanings. If you are debating between 2 sizes and either works with your budget get the bigger of the two.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Clark, NJ
    6
    thanks for the response. how did you mount the pump/filter. did you build your own mounting base?
    thanks
    Jul 2013
    Fletcher, OK
    3,353
    You can use 18x18 1 inch pavers from lowes, you can do a rock base like I did or both, or if your pump comes with a base your good
    here is a shot of both
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,795
    Short of just setting the stuff on the ground simple pavers under the equipment is the easiest solution. You can do what cowboy has done. That looks very nice and tidy and should help keap the equipment dry and free of weeds and grass. I plan on pouring a concrete slab but that's more for the heat pump than just the pump and filter.
    Chuck-
    May 2016
    Clark, NJ
    6
    thank you both for the info, much appreciated. nice pic cowboy, love your setup. sounds like I should go with at least 150sqft maybe even 200. does anyone have the Pentair clean and clear RP, I'm curious if it's better than the standard clean and clear
    May 2016
    Clark, NJ
    6
    I just found out that a 2 speed pump runs at 1/4 of full speed on low, is that correct? so 1 hp pump runs at 1/4hp on low. is 1/4hp enough for 11k gal above ground pool?
    thanks
    Jul 2013
    Fletcher, OK
    3,353
    A 2 speed pump uses 1/4 of the power but moves half the water as high does, I have a 2 speed and it works great on a 15000 gallon pool..
