Results 1 to 7 of 7
Thread: Backwash a few times whitish, greyish or greenish cloud comes out of jets
    Apr 2015
    Nashville
    40
    How do I then find a way for this whitish, greyish or greenish cloud to be drained off from the pool instead of making it go back into the pool. I am still SLAMMING the pool. I noted this clould like thing during after a few months of using the pool and doing backwash would come back again... I think these are TSD or some inorganics...what can I do. I did lower my pool a few inches today during slamming as I had not lowered the pool for a few years now
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Backwash a few times whitish, greyish or greenish cloud comes out of jets
    your going to need to give us some more information
    sand filter?
    what are your test kit levels?
    is it only after backwash or all the time?
    how is the water clarity?
    Apr 2015
    Nashville
    40
    Quote Originally Posted by cowboycasey View Post
    sand filter?
    SAND Filter
    FC 10.5
    CC- 0
    PH 7.2-7.4
    TA 140
    CA 320
    CYA 40
    The water is now nearly bluish but a slight green tint.. but very slight. Cloudy. Yes the cloud comes out from 1-2 jets. It comes out after a backwash.. after say like 1-2 weeks of continuous using the pool. Water can get clear but takes like 2 weeks or more... after that it gets very clear.... I had not change the sand in the filter for 7 years now.. we have cloth pull over the skimmers and Poolskim as well...
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    Aug 2014
    Northern IL
    4,615
    Do you "rinse" after you backwash? Just like when you backwash and look for the sight-glass to run clear, you need to do the same thing when you rinse. Several people have found that they just don't rinse long enough, and a few never knew about rinsing. That would be the easiest place to start.
    Apr 2015
    Nashville
    40
    Quote Originally Posted by MarianParoo View Post
    Thanks so much. By the way when rinising.. do I need to turn the piping valve to let the water go out to drain.. Somehow if I do not do that the water comes back to the pool.
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    Aug 2014
    Northern IL
    4,615
    Setting it on rinse should send it to the same place as the backwash water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Check out the pictures that show where the water is directed in the different modes in Deep Cleaning a Sand Filter
    Backwash sends the water backwards through the sand and out the waste pipe. Rinse sends the water the normal direction but instead of blowing the leftovers into the pool it sends it out the waste pipe.
