Thread: Comment on DE and DE scoops
    Jun 2014
    Bridgewater, NJ
    31
    I just read many posts on measuring DE and using DE scoops, most from 2012 and 2014 and have some comments.
    1) I believe the dry bulk density of 20 lbs/cu.ft. cited by JamesW [and is in an EP Minerals data sheet, attached] is an "unpacked" density. So if you load your scoop and pack it to cram as much DE into the filter as possible, you may be loading too much DE. Whether it is critical or not depends on how much the DE can be compressed, how many backwashes you do before cleaning, and how well you slurry the DE into the skimmer. (I would guess packed, unslurried DE might lead to very uneven coatings)
    2) Not all scoops have the same volume. I saw 48 ounces cited a few times, 24 ounces once, and several comments about how much weight a person's scoop holds without giving the volume. I bought a scoop last fall and called the store a few days ago when I realized it had not markings. I was told it was probably 2 cups..."which would be a pound". Turns out is is 4 cups plus 4 ounces which is, at the 20 lbs/cu.ft. density, is .75 pounds.
    3) As JamesW said in a few posts, the 20 lbs/cu.ft. equates closely to 48 fluid ounces per pound. So unless you like to use a scale, it seems the best way to measure out the DE is multiply the number of pounds you need by 48 fl.oz./lb and divide by the number of fluid ounces your scoop holds. And don't pack it.
    [The opinion on not packing is partly based on what I learned in an engineering course on the properties and handling of powders on an industrial scale. However that was over 30 years ago and I have forgotten over 90% of what I learned so feel free to disagree].
    Attached Files Attached Files
    Irregular shaped vinyl pool - about 22K
    Hayward DE 6020 filter, Hayward Tri-Chlor Feeder
    Aqua Comfort Heat Pump Heater
    Polaris 380
    Taylor K-2006; FAS/DPD kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Comment on DE and DE scoops
    My suggestion it is to buy a cheap digital kitchen scale from Amazon, they have numerous models that weigh up to 11 pounds for under $10. Just make sure to get one you can see the readout , DE has very low density so you often need to weigh in a large container, I use a styrofoam ice chest. Weighing the common 1 pound DE scoops find I have of a 50% variation depending on how I pack the scoop.
    38,371
    I always recommend weighing it, no ambiguity that way.
