Thread: K-1000 replacement parts
    Mar 2016
    Chicago,IL
    88
    I'm wonder if anyone knows where I can buy just the rubber lid to my k-1000 test tubes. Seems to not be on the case and can't find it
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Feb 2015
    Chandler AZ
    927
    Re: K-1000 replacement parts
    It may be impossible to find just the lid... but you can go to Walmart and get a kit with the same comparator block, including the lid, for < $8. Just look for a two-way test kit. And you will also get the reagents to hold you over a bit longer. The one I saw looks to be a re-branded Taylor kit.
    Of course, after you procure a new lid the old one will mysteriously reappear. LOL
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
