Thread: E command 4 - bad board?
    Mar 2010
    Houston
    37
    The heater isn't turning on and the e command isn't keeping time.
    Should there be a voltage across the heater wire? There isn't and I'm afraid I have a bad board.
    It is also losing a couple hours over a few days.
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    38,267
    Re: E command 4 - bad board?
    Sorry for the delayed response, but this is a very specific question that few members will have experience with.
    If it can not even keep time, clearly there is something wrong with it, but I do not know what part(s) you would need.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    When the heater function is activated you would see 24v.
    As for the unit not keeping time, I believe there is a backup battery on the board, just like a computer, and it might be failing.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
