Results 1 to 8 of 8
Thread: Priming/valve question
    Jun 2014
    Bloomington (Minneapolis), MN
    110
    Well, the more I read here the more questions I end up with ha. After coming across several threads about priming the pump I was curious if I had to do anything with the valves after cleaning the pump basket. In the past I haven't been closing any, just filling the basket with water and then turning the system back on. Is this ok or am I missing steps?
    Also, how do you tell what valve controls what as far as returns/stains/skimmers etc..
    Here is my setup:
    Pool: 28K gal, vinyl lined, rectangular, auto cover
    Equipment: Mineral Springs MS-10 SWG, Raypak 266A heater, Jandy CL460 cartridge filter, Pentair superflo 1hp 2spd pump, Polaris PB4-60 booster pump and Polaris 280 cleaner. TF-100 w/speed-stir
    May 2015
    Clarksville
    146
    Re: Priming/valve question
    priming us where you release all the sir from outlet of the pump, hoses, etc. there should be a couple little knobs or nozzles you turn to prime. yes emptying, cleaning the basket is one of the steps, but just refilling it with water won't prime it.
    Intex 18/52 pool at 7000 gsllons.
    vinyl sift sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
    vinyl soft sided pool
    38,514
    I don't close any valves or fill the pump with water. You can not fill the pump with water because it will always drain back to the pool through the suction line.
    If you pump is not many feet above the water level, there is usually nothing special to do. Just put the lid on fire up the pump and it should fill with water in a minute or so. Most filters also have an air valve on the top that should be opened when the pump is priming to let the air out of the system.
    Jun 2014
    110
    Awesome, thanks. Mine fills fine, just wanted to make sure I wasn't damaging the system doing it the way you described.
    So there's really no reason to ever mess with the valves once the pool is open for the season?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Quote Originally Posted by Scsu74 View Post
    That depends. I'd at least identify which valve goes where. I like to keep my main drain almost completely closed off. It still gets enough flow to stop temperature stratification but sends the majority of the suction to the skimmer, so it grabs surface debris better. But if I've suffered through some windy days and the pool is full of dust, I go for maximum drain and minimum skimmer and hope that as I'm brushing, the stuff makes its way to the drain.
    Jun 2014
    110
    How do you tell what goes where? I have 2 skimmers, 2 deep end drains and 3 returns
    Richard320's Avatar
    Jan 2010
    19,058
    Experiment. It's just like figuring out which light switch works which lights and which plugs in a new house.
    Shut off a valve and go check to see which skimmer has stopped flowing. If you have both skimmers shut off and the pump is still pumping, you've identified the main drain. The two drains should be teed together underground and have a single pipe to them both.
    I can't tell if those unions on the return side have a shut off in them or what. Maybe that's an air bleed, maybe someone removed the handles.
    I also wonder if that's really a sand filter or if it's a cartridge, because I see no backwash valve.
    Jun 2014
    110
    Thank you for the help. It's a cartridge, Jandy cl460. It takes 4 filters.
