Results 1 to 12 of 12
Thread: Calcuim Hardness low after purchasing water softner
    Sep 2014
    San Antonio
    10
    Hi!
    My calcium hardness is reading very low (100), the calcium hardness increaser that I purchased said that I need to add roughly 20 lbs to increase by 150 for my pool size (12,000 gal). Is this safe to do? I am a little apprehensive to put that much in at one time. Before we bought our new water softener the CH was always reading at acceptable levels (the plumber installed the softener in the garage so all water entering the pool is softened.)
    I have a t-100 test kit and here were my readings from todays test
    FC- 5
    CC-0
    TA-120 (Been lowering it over the last week from 170!)
    PH- 7.5
    CH- 100
    CYA- 40
    Thanks!
    Jun 2014
    15,255
    Re: Calcuim Hardness low after purchasing water softner
    Amber, your signature doesn't tell us ... do you have a plaster, fiberglass, or vinyl pool?
    Also interesting ... when I had my softener installed in the garage, it softened everything EXCEPT for the outside water hose bibs. Part of that was to avoid damaging plants. Are you sure the outside hose bibs are soft water as well? You could always do a CH check on those separately.
    Sep 2014
    San Antonio
    10
    Hi! Sorry, we have a plaster pool
    I will test the fill water now. I assumed fill water was low because the test was reading so low.
    Sep 2014
    San Antonio
    10
    I just tested my fill water (the one that goes directly into the pool from the outside) and my reading was only 25...twice! That is cuckoo-bananas.
    With that being said, I for sure need to keep raising my calcium hardness right?
    How much of the calcium hardness increaser can I safely add each time?
    Thank you for all of the fabulous advice
    12,000 Gal, Plaster Pool. Built 1984. HAYWARD sand filter pump model S244S.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, you definitely need to raise it. That is the lowest CH ever. You can add enough to raise it to 250 ppm. Broadcast it on the surface of the pool with the pump running and brush the pool to circulate. It will dissolve quickly.
    Jun 2014
    15,255
    How can we be in the same area and have such different water? Oh yeah, Edwards Aquifer I guess. Not me though. Well, it's good you know for sure. Adjust and have a great weekend.
    Sep 2014
    San Antonio
    10
    Yeah the test was very bizarre. I drop of the 12 regent and it turned blue. Crazy low CH. Thank you everyone!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might want to see about adding a bypass connection for your water softener.
    Jul 2015
    Western NC
    115
    Our fill water has CH=75. It's not that big a deal - I added 30 pounds when I opened the pool a couple of weeks ago. The instructions said to divide the total dosage into thirds and wait at least 6 hours between additions, so I did that.
    I don't think you'll lose a lot during the season unless you have a lot of splash-out.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Jul 2015
    Western NC
    115
    BTW, the product I used was Clorox Calcium Hardness Increaser.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Wow that stuff is pricey, one of the local hardware store chains has 20 pound tubs for about $20
    Jul 2015
    Western NC
    115
    Quote Originally Posted by Isaac-1 View Post
    They may have it even cheaper in China - but I don't live there either.
    And I prefer having stuff delivered to my door. It saves time.
    I am quite happy with the product I linked to above. I know that it works, and I expect the $72 I spent to last most of the season here.
