Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: First time TF100 results
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Lightbulb First time TF100 results
    These results are 9 hours after the pool guy added a large amount of what he called "super shock"
    FC - 5.5 ppm
    CC - 0.5 ppm
    pH - > 8.2
    Calcium - 275 ppm
    Alk - 140 ppm
    cya - 25 ppm (or less).
    What im wondering is: are these results meaningless bc of the large amount of shock added today or does this seem right? Pool company said don't do anything for a week in terms of adding other stuff.
    Seems like no cya which makes sense and high ph. Should I do something about this sooner?
    27,000 gal concrete rectangle, built Oct '15, DE filter, Jandy PHPM 1.5 HP, Hayward HP21104T heat pump, TF-100
    Jun 2014
    15,103
    Re: First time TF100 results
    Depends on the type of shock added John. If it had stabilizer in it, then the CYA may continue to creep-up for a couple days. If it was just Cal-Hypo, then there is no stabilizer at all - only calcium (CH). I would check the CYA tomorrow evening. If it's still below 30, then increase a little bit. pH definitely needs to be lowered right away - mid 7s. FC good at that level. Later, we may work on lowering the TA which will also help to keep pH down, but focus on the pH and CYA for now.
    38,284
    Has the pool guy been fired yet so that you can take control?
    Your FC is not high enough for the pool to be neglected for a week. You will likely need to add some chlorine by tomorrow.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ditto... what is your daily chlorine method?
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Haha. The guy was just there to open. It's all me now.
    I want to do the bleach method of chlorination. That's the plan. This is the first time the pool has really been open. (Just built)
    I went to the trash and saw about 4-5 bags of sodium s dichloro triazinetrione. So that has cya built in I think. Tomorrows plan will be acid and I'll grab some cya just in case.
    38,284
    Yes, Dichlor has CYA and is acidic which should have lowered the pH.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Ok so after the second day I focused on pH and general cleaning (lots of vacuuming and backwashing). It took about 2/3 of the jug of muriatic acid, over 4hrs or so, to get the pH into the mid 7s from very very red >8.2. FC was at 1ppm and CC was 0.5 after the day. So big drop in free chlorine in a day after the opening shock. I didn't do any other tests because I was focused on ph. Tomorrow morning I'll do a complete test and then use the calculator to add bleach. I bought bleach and baking soda today at Costco.
    Then ill hit the pool store for CYA bc I'm guessing I'm low. Huge guess there. Then I'll deal with that.
    Im glued to the pool school pages but one thing I'm not grasping is the numbers behind target chlorine levels and CYA levels and how they are related. Should I deal with CYA first or try to get chlorine up a bit and then do CYA?
    Jul 2014
    Hope Mills, NC
    567
    CYA and chlorine are linked to each other. They should be adjusted together.
    If you raiise chlorine and not CYA, the sun will burn off your chlorine. If you raise CYA and not chlorine, you leave yourself open to organics attacking your water.
    Add CYA to the correct level per math and raise chlorine as if the CYA is already there.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    38,284
    You can get the CYA at Walmart or hardware stores with pool seconds.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Just got it at Walmart. I need 108oz! That's a big sock!!!
    Jun 2014
    15,103
    You can hang 2-3 socks around your returns if needed John. Squeeze them occasionally and most of the granules will dissolve to power by the end of the day.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Thanks Texas. Got my socks. Doing a quick backwash first. Starting to panic a bit. Had zero chlorine this am. Dumped a whole jug of bleach. Trying to get this cya in before the sun roasts it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Good plan!
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Socks at the returns work great. Looks ghetto but hey whatever works. TC is around 3 right now so hopefully that will hold during the day.
    The thing im wondering about now is maintenance. How much bleach to add daily to keep this going? Trial and error I guess. TC/CC and CYA each night and then adjust and then get a feel for how much to dump daily?
    Its so clear and gorgeous. This is great! Chemistry plus swimming; I'm thrilled. This site is fantastic.
    Jun 2014
    15,103
    Looking good! Yeah, you'll get the hang of adjusting FC soon enough.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Ok so after a day of squeezing socks....
    CYA - 40 YES!
    FC - 1.5
    CC - 0.5
    soooo, should I spike this baby to 5ppm chlorine tonight?
    i also note that my pH dropped to 7.2. Wasnt expecting that.
    Any ideas?
    38,284
    CYA is slightly acidic.
    Get the FC up asap.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Thanks. I upped it to 5 with a jug of Walmart "bleach".
    Its probably wise wise to end this thread then I'll post specific questions as they arise.
    THANKS!
    Jun 2014
    15,103
    Good luck John. I think you've got the basics. Let us know if anything odd happens. Have a nice evening.
  20. Back To Top    #20
    38,284
    Just make sure you never let the FC drop below 3ppm.
