Thread: Stabilizer help!!
    Jul 2014
    Hudson, wi
    81
    Stabilizer help!!
    I need some help. I need to add more stabilizer to my pool but no one has any in stock yet but the stuff made by Utikem which isn't Cyr... acid. Has anyone used this product and will it work for me? https://www.menards.com/msds/111795_001.pdf
    The link shows what is in it. Thanks
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Stabilizer help!!
    Take a look at this thread:
    cyanuric acid vs Isocyanuric acid
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Donldson's Avatar
    NW Ohio
    2,893
    Hehe, yeah, it is CYA. Took me a little researching to confirm it too: Well this was a first
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2015
    Central Valley CA
    1,107
    could also just float some pucks till you get where you want to be.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2014
    Hudson, wi
    81
    Great info...Thanks for the help. I'm starting to doubt my ninja googling skills, normally I would have picked this out right away. Thanks for the help.
