Results 1 to 16 of 16
Thread: To Drain or Not...
    Jul 2015
    Phoenix
    72
    To Drain or Not...
    So here are my current pool water readings:
    FC: 3.5
    CC: 0
    TC: 3.5
    pH: 7.6
    TA: 100
    CYA: 150
    CH: 750 (a pool store read 750, while I get 450 with my Taylor 2006 kit??)
    My pool was resurfaced (pebble) exactly 1 year ago and filled. It has only been "shocked" once when the pool was first filled by a pool service. The pool service was using trichlor pucks during this time, which explains the high CYA. I live in Phoenix, so I'm guessing the high CH is from all the water evaporation that takes place in the summer, since the CH of the fill water is much lower (150 I believe). Just wanted to see if the CYA and CH readings seem "reasonable" for 1-year old pool water in Phoenix(?).
    Secondly, I wanted to verify the recommended action would be to do a partial/full drain of the pool water (based on the CYA and CH levels). I no longer use a pool service, so am trying to decide if fetching/storing bottles of bleach is going to be practical for me (rather than using pucks and draining the water every year).
    Any thoughts and/or recommendations are much appreciated.
    18K gal, 32' x 17' IG, pebble - Hayward SwimClear C5030 cartridge filter, 2HP Hayward pump, Hayward W530 leaf canister, Hayward AquaNaut 200 automatic pool cleaner, Taylor K-2006 test kit
    Jun 2014
    15,096
    Re: To Drain or Not...
    We can work with the high CH by off-setting with a lower pH and TA, but for the CYA .... there's no avoiding the partial drain. Sorry. But now you know. Get that CYA down to at least the 50-70 range for your area, then you know it will never increase again unless YOU want it to.
    I don't see it mentioned, but PLEASE make sure you are testing the water with your own TF-100 or Taylor K-2006. That's a major priority.
    Jul 2015
    Phoenix
    72
    Thanks for the response. Yes, I have a Taylor K-2006 kit (see mention of it next to my CH reading). I'll add it to my signature...
    Jun 2014
    15,096
    Yup, there it is. Well, let us know if you have any more questions.
    Jul 2015
    Phoenix
    72
    I've been looking around Pool School and other posts, but haven't found something like a "step-by-step" for refilling a pool... steps to refill and in what order to address chlorine, pH, CYA, CH, TA, etc. If someone has a link to something like this, please post.
    Jun 2014
    15,096
    Not really listed in that way that I'm aware of (but I'll look) because everyone's scenario is different depending upon how much water is removed. But one rule is always a priority .. validate CYA so you know how much FC to have (see Chlorine/CAY Chart link below). Also ensure pH is in the mid-7s, and that's a good start. Al the recommended levels are in the link below in my sig as well - but in no specific order.
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by NLITP View Post
    I just did a drain/refill...Tested pool when full, I added CYA per Pool Math, then FC, my pH was little high added Acid, my TA & CH were ok, tested a few hours after adding chemicals (CYA will take a few days to fully register)...and just normal testing adding etc after that.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    38,275
    There is no step-by-step because adjustments depend on the test results. I recall someone tried to make a flow diagram with all the what-ifs and it was impossible to follow
    Jul 2015
    Phoenix
    72
    Quote Originally Posted by oldguy70 View Post
    Question... when you are adding chlorine, are you attempting to bring the level to match your estimated CYA (since it takes a few days to fully register), or are you attempting to bring the chlorine to "shock" level (again, based on your estimated CYA).
    I'd also like to know if people would recommend doing several partial drains or doing a full drain based on my current CYA and CH. If partial, 20%... 50%, other?? Thanks!
    Jun 2015
    Glendale, AZ
    156
    I first added CYA target 50...then added FC to 3 ppm, after 2 days my CYA was at my target of 50, then I bumped the FC to 6 (Pool Math)
    38,275
    In your area with no ground water to worry about and a pebble pool, you can do large drains which is more efficient. It is cooler this weekend so a good time to do it ... try to keep the surface moist if the sun is shining on it.
    The FC level you target depends on what you are trying to do. Either maintenance level or shock level depending on your CYA.
    Jul 2015
    Phoenix
    72
    Right. I was just wondering for a pool "start up" (after a drain) if it was recommended to immediately bring the pool to shock level. Based on your approach, I'm assuming shocking after a refill isn't required.
    Thanks for all the info.
    Jul 2015
    Phoenix
    72
    Should I be running the pool pump longer than normal after the refill for any reason? I've never had to add stabilizer before, so don't know if it needs to run longer to dissolve it.
    I'm picking up a rental pump at 10am this morning to do a full drain/refill today. Wish me luck.
    Jun 2014
    15,096
    Not really. All you did was a drain and no plaster work. So once the stabilizer is all dissolved from the sock(s) and in the water, just continue normal scheduled circulation.
    Jul 2015
    Phoenix
    72
    Good to know, thanks.
    I didn't start the drain until 11am today, so I'm guessing it will be done around 9 or 10 tonight. Yea, me!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    That is not bad.........you will get to start the refill before you go to bed. Sweet dreams of water flowing into your pooll
    Kim
