Thread: Chlorine reading going up?
    Jun 2015
    Charlotte, NC.
    82
    Hey all,
    I took a sample and tested (TF-100 powder test) about 15 minutes after my pump and swg stopped running and got a reading of 4 (8 drops). An hour later (no pump in the meantime, no SWG, plenty of sunlight around lunchtime) same spot/depth in the pool tested at 6 (12 drops). Any ideas? I have also noticed that if I take a reading in the afternoon/evening shortly after the pump stops, and again in the morning around sunrise (nothing is currently running at night) I also sometimes see a rise of 1-2 ppm in the test. If the difference was only a drop or two I would call it my error, but the difference is often 4 drops or more (2 ppm)
    Is this a striation/circulation issue with the pool? is it taking that long to distribute fully around the pool? Or does chlorine rise towards the surface and that's why my reading goes up after the water has been still for a while?
    Readings are always taken from the same spot in the deep end (6' pool depth). I put my hand in the water up to my elbow (about 1 foot deep) and fill the sample container from there.
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Jun 2015
    Glendale, AZ
    156
    Re: Chlorine reading going up?
    I take all my readings, when all chemicals mixed well and 1/2 hr before the pump shuts off.....Consistent, repeatable, accurate
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jun 2015
    Charlotte, NC.
    82
    Problem with before is that my system is making chlorine so the reading will be high because of return jet location and circulation.
    - Matrioux
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Having an extra 1 or 2 ppm of FC isn't too big of a deal. There are only two options I can think of, run your pump to mix the water or brush the pool to mix your water. Take samples from a couple of places and use the lowest one to make sure FC is at target and doesn't drop below minimum.
