Thread: Test Results K-2006
    Apr 2016
    Alice, TX
    2
    Test Results K-2006
    Water is clear, no major problems, except when it rains, it gets a little algae on bottom and walls of the Infinity trough. I easily treat with liquid chlorine.I have Well Water. I want to get my levels corrected, so should I start with draining 2/3 of the water and bring down CYA? And then start correcting the others?
    CYA Over 100
    FC 2
    CC 1
    PH 8.0
    TA 400
    CH 275
    Pool is only 2 years old.
    Thanks for any suggestions.
    15' X 30' 15,000 Gallon Pool Gunite Infinity Edge, Spa, Turbo Clean System, Catridge Filter
    Taylor K-2006 Kit
    38,539
    Re: Test Results K-2006
    Welcome to TFP!!!
    Getting the CYA down to a reasonable level is certainly the first step. Whether you try to do a large water change or multiple smaller ones.
    Your FC is certainly too low for your CYA and that is why you keep seeing algae.
    After the CYA is reduced, then you need to follow the ShockLevelAndMAINTAIN Process
    Jun 2014
    15,292
    I agree. Do some water exchange first before trying to adjust anything further. For what it's worth, try to shoot for a new CYA of around 50. You'll use a little more bleach for the SLAM, but you might save some time. Summer is not too far away, and if you get much sun during the day like I do, your FC will need that CYA protection. In the future, make sure to stay away from those pool store chlorinating products that increase CYA so quickly (tablets, pucks, bags of shock, etc).
    Great to have you with us.
    Apr 2016
    Alice, TX
    2
    Quote Originally Posted by Texas Splash View Post
    Thank You for the info. I'll try water exchange first, then SLAM. So instead of the Chlorine tablets, I just buy household Bleach? Where do I find application rates? Do I just pour it in?
    Thanks. I'm learning and you guys are a big help!
    Taylor K-2006 Kit
    Jun 2014
    15,292
    Please refer to the Poolmath link below in my sig or from the Home page (Poomath tab). It's fantastic. Refer to the FC row and enter your NOW and TARGET/GOAL FC numbers. Make sure to manually enter the weight (percentage) of bleach you are using on that row. Yes, regular bleach, generic is fine. Bravo from HEB or Great Value from Wal-Mart. No scented or splashless bleaches though. Just the regular plain stuff. Add slowly near a return jet with water circulating. Feed your pool everyday. Easy stuff.
    38,539
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    The 3rd link describes how to add each chemical.
