Thread: Advice about pump change
    Feb 2016
    St Petersburg Fl
    3
    Our pool builder put in a 5hp Hayward TriStar pump which was too loud and too big to preform corectly. It was switched out to a 3hp Hayward EcoStar variable speed pump, which seemed to us to be working corectly. The pool builder has acted unethically in several instances, so now I feel I need to check everything he does. Two weeks after the pump was changed out the plumber showed up and told us he was told to change the computer (brain) that controls pump. He seemed to be confused as to why he was changing it, he was given an open taped up box by the pool contractor, which concerned him.
    Are there different computers necessary for these pumps or is something odd going on here?
    Tina
    15k gal, negative edge spa, 33 ft negative edge, in ground 1/2 above ground, Jewelscape, Hayward cartridge filter 57030, 2 Hayward pumps.
    38,301
    Re: Advice about pump change
    Sounds weird to me ... seems like you should talk to the builder to find out what he is doing.
    Feb 2016
    St Petersburg Fl
    3
    The builder is causing all of the problems, he will not answer truthfully. Do you know if the pumps use different computers to control them?
    38,301
    Not as far as I know.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    The 3hp VS pump has its own built in timer/controller. More here, EcoStar | Pumps | In Ground Pool Pumps - Hayward Pool Products
    There is also pool automation that the pump(s) could be connected to but you don't list any pool automation in your signature, like prologic or omnilogic. Either pump could be connected to any Hayward pool automation system.
    More on Hayward pool automation here, Pool Automation | In Ground Pool Automation - Hayward Pool Products
