Results 1 to 11 of 11
Thread: HASA Chlorine
    Apr 2016
    Phoenix, AZ
    22
    HASA Chlorine
    I bought some HASA 10% chlorine from a local pool supply store here in Phoenix, AZ. They told me the manufacturer of the chlorine usually produces it at a higher percentage (around 15%) so by the time it gets transported, put on their shelf, sold, and used, it ends up being around 10%. Is that true? If so, do other chlorine manufacturers do this as well?
    Also, the Lot Number stamped on this box of chlorine was B1206. Can anyone help me decipher this, as to when it was produced?
    Thanks!
    Phoenix, AZ | 30,000 Gallon Pebble-tec pool + attached spa | Hayward cartridge filter | Pentair Intelliflo Variable Speed Pump | In-ground pop-outs | Taylor K-2006 Test Kit
    38,521
    Re: HASA Chlorine
    That is generally true. Often the really fresh stuff is a little stronger.
    I am not sure how to decipher that stamp.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: HASA Chlorine
    It might be 120 th day of 2016?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Glendale, AZ
    156
    Re: HASA Chlorine
    Quote Originally Posted by SunDevil1 View Post
    Thanks!
    I get the HASA chlorine from a dealer in Glendale AZ, it is labeled 12.5%, I am sure Phoenix gets the same stuff...never had an issue and seems to check out at 12/5%
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: HASA Chlorine
    it should have a date/time stamp on the bottle itself
    Apr 2016
    Phoenix, AZ
    22
    Re: HASA Chlorine
    Quote Originally Posted by oldguy70 View Post
    Is the 12.5% for the refillable bottles? I've contacted all of the HASA dealers located close to me and they only sell 10% in the disposable bottles.
    38,521
    Re: HASA Chlorine
    Yes, usually the 12.5% is the refillable I think
    Apr 2016
    Phoenix, AZ
    22
    Re: HASA Chlorine
    Quote Originally Posted by cowboycasey View Post
    I've purchased chlorine from Home Depot and the HASA chlorine, and neither had anything stamped on the bottle! Go figure
    Jun 2015
    Glendale, AZ
    156
    Re: HASA Chlorine
    Yes, in refillable white plastic gal bottles. I would almost bet what you are buying if it is the HASA is the same stuff.
    Call the Pool Parts Plus at 67th Ave & Bell Rd, there is another I think it is around 59th Ave & 101 (I don't have the numbers), ask them what they have...may even be some of these in your area
    Also go on the HASA web site for info & dealers
    Apr 2016
    Phoenix, AZ
    22
    Re: HASA Chlorine
    Thanks for the advice! If you don't mind me asking, how much is it per gallon for the refillable white plastic bottles? None of the HASA dealers closest to me offer this, but if there is a significant price savings I might be willing to drive a bit further to the closest one I can find (I'm off of Warner & I-10). I'm paying $6.89 for 2 gallons 10% at B&B Pools on Baseline & McClintock
    Jun 2015
    Glendale, AZ
    156
    Re: HASA Chlorine
    I purchased a 4 gal case on 4/21/16 $14.36 plus tax (there is a deposit on the bottles & case, I think like $10, but once you do that, just bring back & exchange for another.
