Thread: 2 Weeks After Opening
    May 2015
    Ontario, Canada
    10
    So it's been 2 weeks after opening my pool (did it myself this year) and here are my test results:
    FC - 4.5
    CC - 0
    CH - 200
    TA - 90
    PH - 7.5
    CYA - 25
    Last summer my CYA was up to 60+ but that was my fault because it was my first year with a pool and I thought with the automatic chlorinator you just crank it up and get the chlorine level up (doh), well I quickly learned that the pucks have stabilizer in them. Anyway I figure now I can bring my CYA level up, but I was just wondering what I should set the dial on my Hayward chlorinator to? Also do I need to do anything else except wait for the warmer weather to get here?
    Thanks
    19 X 36 Vinyl IG - Sta-rite 1HP Pump MPRA6E - Sta-rite Cartridge Filter S7M120 - Delta UV Filter E40 - Hayward Offline Autofeed Chlorinator CL220EF - Sta-rite Heater SR333NA - 16000 Gal
    Jun 2014
    15,059
    Re: 2 Weeks After Opening
    Steve, those looks like some rock-solid numbers for just opening. I would recommend watching the CYA because it's borderline getting low - maybe even add just enough stabilizer for another 10 ppm. Oh wait, you have an in-line with tablets right? SO just open that up a little more and check CYA in about a week or so. Those dials are not the most accurate. But everything else looks really good. You must've done a good job closing last season. Enjoy your weekend.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Those are some nice looking numbers
    what size pucks do you have? use the bottom of poolmath and see how many pucks/oz to add to bring your CYA up to 30.. it will bring you PH down and add salt.. or you could just add granular stabilizer
