Thread: Deck joint
    May 2016
    Florida
    2
    Deck joint
    Hi,
    My in ground pool was built 2 years ago and I have a concrete deck. I recently noticed that one side of the pool has no expansion joint between the slab and the coping. So far, I have had no cracks, but I am concerned it could crack the pool. Shall I cut an expansion joint at this point, or shall I consider that if I haven't had any issue so far, it should be ok ? What would you do ?
    I am in Florida, lowest temp around 32F.
    Thanks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Deck joint
    Welcome to TFP!
    How wide is the deck in that area? And what is on the other side of it? If it isn't too wide and doesn't butt up against a non-movable surface on the other side then I am inclined to leave it since there have been no issues, you don't freeze and probably have sandy, fairly well draining soil.
    May 2016
    Florida
    2
    Re: Deck joint
    Thanks.
    It's about 4 feet, then I have a drain, then another 4 feet to another concrete slab, then a joint and another 4 feet of concrete. (hope it makes sense).
    So I guess I have enough joints that it can expand to ?
    DFW, TX
    24,468
    Re: Deck joint
    Yep, makes sense. Sounds OK to me.
